Page 13 of 23 FirstFirst ... 31112131415 ... LastLast
Results 121 to 130 of 225
Thread: Great Tropo At Remote DTV Site in IL
  1. #121
    734
    I wish I could have a 24/7 setup out there in Medina.
    Andrew, you're pulling in some real fine DX. Medina especially seems to be a great location. I think some day you're just going to move to Medina!
  2. #122
    1,760
    RE: the overheating power supply...
    I'd be looking for corrosion / water in the connectors / feedline.
  3. #123
    Nov 2010
    Lebanon, IN
    102
    Good thought. I'm planning to replace the coax soon.
    Mike Glass N9BNN
    Lebanon, IN
    EM69
  4. #124
    356
    Ed, good thought but I had to remove my Research Communications preamp from my tower over a month ago because it simply stopped working one day. After testing with Mike's unit here at my house earlier in the summer, I noticed a slight positive margin with it over the Winegard HDP-269 that Mike and I had been using. When I first hooked up the RC unit on my tower, and PRIOR to cranking the tower up, I checked it out and NOTHING. Talk about being ticked off! I removed it and then tested it indoors and it worked. DUH. I kept trying to figure out why I wasn't getting any signal through the line. I finally switched out the indoor UVSJ I was using to a CM combiner, and it worked. So I cranked the tower up and it worked for about two months and then stopped working. I then removed it and remounted the HDP-269 and it has continued to work without fail. As for the RC unit, I once again tested it indoors and it worked. Greg B. used an RC unit some 10 years ago and had several issues with it, too. When those units work, they are good, but too many of them seem to be too picky, flakey and unreliable. I doubt I'll ever buy another. I plan to test it more with my mobile setup, as long as it works......................
  5. #125
    Tabernacle, NJ
    323
    I just wanted to add how blown away I am regarding the WCBS reception. That's one of the great logs. (Unfortunately nothing noted here checking FM that morning) Awesome job, guys.
  6. #126
    356
    Sixteen new DTV logs, including some Canadian catches, from IL DX site Dec. 4 - Dec. 5. Thanks again to Mike G. for engineering and setting up this interesting DX setup. It's fun to control.
    W50DR-D 50/10, La Crosse, WI 291 miles. Translator for KTTC, Rochester, MN. New log #431.
    WLFG 49/68, Grundy, VA 397 miles. New log #432.
    WCVN 24/54, Covington, KY 198 miles. New log #433.
    WKMR 15/38, Morehead, KY 281 miles. New log #434.
    WSAZ 23/3, Huntington, WV 322 miles. New log #435.
    WKHA 16/35, Hazard, KY 336 miles. New log #436.
    WYMT 12/57, Hazard, KY 336 miles. New log #437.
    WTCT 17/27, Marion, IL 226 miles. New log #438.
    WBQC-LD 47/25 "WKRP" Cincinnati, OH 195 miles. New log #439.
    WVAH 19/11, Charleston, WV 341 miles. New log #440.
    WQCW 17/30, Portsmouth, OH 274 miles. New log #441.
    WXIX 29/19, Newport, KY 193 miles. New log #442.
    WBDT 26/26, Springfield, OH 188 miles. New log #443.
    CFMT 47/47, Toronto, ON 469 miles. New log #444.
    CBLT 20/5, Toronto, ON 469 miles. New log #445.
    CIII 29/29, Sarnia-Oil Springs, ON 315 miles. New log #446.
    CFPL 10/10, London, ON 363 miles. New log #447.
Name:	WLFG 49 dec 4 2015.png
ID:	18327Click image for larger version.
Name:	WKMR 15 dec 5 2015.png
ID:	18328Click image for larger version.
Name:	WSAZ 23 dec 5 2015.png
ID:	18329Click image for larger version.
Name:	WYMT 12 dec 5 2015.png
ID:	18330Click image for larger version.
Name:	WKRP WBQC 47 dec 5 2015.png
ID:	18331Click image for larger version.
Name:	WVAH 19 dec 5 2015.png
ID:	18332Click image for larger version.
Name:	WBDT 26 dec 5 2015.png
ID:	18333Click image for larger version.
Name:	CFMT 47 dec 5 2015.png
ID:	18334Click image for larger version.
Name:	CBLT 20 dec 5 2015.png
ID:	18335Click image for larger version.
Name:	CIII 29 dec 5 2015.png
  7. #127
    980
    At this rate it won't be long until it hits #500!
  8. #128
    Nov 2010
    Lebanon, IN
    102
    It's great to see how well you operate that remote site, Steve.
    Mike Glass N9BNN
    Lebanon, IN
    EM69
  9. #129
    356
    While looking for tropo DTVs, Es popped up from SD into the IL DX site around 5:40 p.m. EST. Received KOTA 2/3, Rapid City, SD 832 miles and KDLO 3/3, Florence, SD 587 miles. Both relogs.
Name:	KDLO 3 dec 7 2015.png
ID:	18355Click image for larger version.
Name:	Es KOTA KDLO dec 7 2015.jpg
ID:	18356Click image for larger version.
Name:	Es dec 7 2015.jpg
  10. #130
    639
    Nice going on the e-skip Steve. I have my low-VHF antenna down for the season. I'll put it back up in April. I still need to log KDLO here. I think I'm going to need a good FM filter here, because the nearby FM blowtorches seem to be making it harder for the DTV e-skip to come through the interference.
