Results 1 to 10 of 16
Thread: E-skip in Ohio
    Default E-skip in Ohio
    KOTA was received here last night 1/20/16. I was thinking the winter e-skip was over, but apparently not. There were also a couple sub-decodes on channels 3 and 5.
ID:	18487Click image for larger version.
ID:	18488Click image for larger version.
    360
    Great to see the new VHF-lo antenna is working well for Es.
    Here are some photos and video from today's e-skip to Nova Scotia and Maine. Signals received were WLBZ Bangor ME @ 702 miles and CJCB 4 Sydney NS @ 1125 miles. There was also a channel 3, likely CJCB6 from Port Hawkesbury, NS. The videos of CJCB show just how clear the picture quality was.
ID:	18807Click image for larger version.
ID:	18808Click image for larger version.
ID:	18809Click image for larger version.
    4 CJCB - https://www.youtube.com/watch?v=q-NPGShj0ZQ
    4 CJCB - https://www.youtube.com/watch?v=hQVAgfmc7Q8
    2 WLBZ - https://www.youtube.com/watch?v=H1vooGfxza8
    3 likely CJCB6 - https://youtu.be/JgkF4Dls51E
    Wilkes-Barre, PA
    318
    You got some really nice stuff out there. I've been monitoring since 8:45 this morning. I saw about 10 seconds of an analog channel 4, just frame bars, then 2 hours later about 20 seconds of weak skip on 91.3. Looking at the skip map I can't believe more hasn't broken through today. It all depends on where you are. Maybe later.
    Quote Originally Posted by H Hayes PA View Post
    Harry, it was great for a couple hours this morning on low-VHF. I'd never seen CJCB that strong before. I also noted a sub-decode on the Zenith box on channel 3. There is only one channel 3 up that way... CHAU1 in Quebec, but it never decoded ... maybe next time. Throughout the day, it has been very fluttery and struggling to get into FM. I did manage to ID 96.9 KXBJ from El Campo Texas, but it was really weak. I'm just glad to finally see a DTV via e-skip.
    Wilkes-Barre, PA
    318
    Congrats on getting WLBZ. When skip is out that way I always check for digital stations. It seems to me there is a digital station in the Canadian Maritimes somewhere but I'm not sure of that. I have seen WLBZ here in analog years back so I look for this also but no luck yet.
    CIMT-DT-1, Edmundston, New Brunswick. Channel 4 with 2.22kw.
    It's a translator of the TVA station in Riviere-du-Loup, Quebec.
    CHAU has three up in that area on DT 3, 4, and 5. It seems that all have been logged by DXers in this group. I saw the DT 3 yesterday, which didn't decode, probably because the analogs in that area interfere.
    Yes, there are more in Quebec but that's not technically the Maritimes (sorry!)
    Let's see...
    CHAU-DT ch. 5 Carleton (48-08-08N/66-07-04W) 9.85kw/483m
    CHAU-DT-1 ch. 3 Ste.-Marguerite-Marie (48-18-41N/67-05-03W) 1.567kw/206m
    CFTF-DT-4 ch. 4 Forestville (48-48-32N/69-00-26W) 1.9kw/144m
    CHAU-DT-7 ch. 4 Riviere-au-Renard (48-59-51N/64-25-53W) 990w/228m
    I think that's it..
    FWIW elsewhere in Canada...
    CHFD-DT ch. 4 Thunder Bay, Ont. (48-31-27N/89-06-53W) 1.2kw/366m
    CKPR-DT ch. 2 (same antenna & power as above)
    CITL-DT ch. 4 Lloydminster, Alta./Sask. (53-23-47N/110-00-30W) 9.1kw/221m
    CKSA-DT ch. 2 (same antenna as above but only 8.1kw)
    Decode of KHME 2/23 here in Akron Ohio this evening (1,120 miles). TSID still shows up as "KOTA".
ID:	19131Click image for larger version.
Name:	KHME Signal.jpg
ID:	19132Click image for larger version.
ID:	19133Click image for larger version.
