Results 1 to 8 of 8
Thread: Unknown DTV Signal WG9XGV
    644
    Default Unknown DTV Signal WG9XGV
    I'm currently not home to verify what is being broadcast on this unknown channel. My antenna is aiming southwest, and I can't rotate the VHF antenna. I wonder if it's more ATSC 3.0 testing from Cleveland, but I'm not sure. Should I count it as a new log?
    2,355
    The callsign belongs to the National Association of Broadcasters and in 2013-14 was associated with an ATSC DTV repeater test centered around the Potomac Mills Mall in Woodbridge, Virginia, but not now...
    "This STA is requested in conjunction with the ongoing work by the Advanced Television Systems Committee (ATSC) to develop the next-generation TV standard (ATSC 3.0). The facility requested in this STA will be used to test the various components being proposed for the new standard, in particular those related to use of VHF frequencies, as well as allowing for a comparison to the existing standard. In order to conduct a meaningful field test it is necessary to deploy a full scale system.
    The proposed facility will operate on channel 9 (186-192 MHz) with a non-directional antenna and an effective radiated power (ERP) of 10 kW. The antenna to be utilized is a Harris Model TAB-3H and is currently the authorized auxiliary antenna for WJW channel 8 Cleveland, OH who has agreed to allow the use of their auxiliary antenna for this project. The antenna is side mounted (179 m AGL) on an existing registered tower (ASR: 1054608) with an overall height of 266 m AGL."
    So this signal is in Cleveland.
    You really should contact the NAB research department as they are likely to have more information (or would be interested to hear of your reception perhaps?).
    644
    I got photos. It is broadcasting Oregon Public broadcasting on the three channels. It is indeed an ATSC 3.0 test channel originating from Cleveland.
ID:	18503Click image for larger version.
ID:	18504Click image for larger version.
    2,355
    That is an amazing catch. Never would have thought Oregon Public Broadcasting would have supplied the test material!
    Danville, IL
    143
    I figured as much that it was an ATSC 3 test.WG9XGV indicates an experimental station (the X immediately following the number), and Cleveland has been home to another ATSC 3 test site. Good, they're running a test station on VHF-Hi. I hope they do the same for VHF-Lo before the standard is finalized.
    Daniel KC9HZN
    Danville, IL
    EN60
    Grundig G3 (stock antenna)
    GigaWare HD Radio dongle
    Sony CRT TV, DigitalStream Converter Box, Terk HDTVa antenna
    Car radio (stock, no HD, no RDS)
    644
    Quote Originally Posted by kc9hzn View Post
    I wasn't aware of these plans to do further testing of ATSC 3.0. Last year, testing was done on RF 31 here locally in the Cleveland/Akron market. But I thought that was all they had planned. I came across this when I looked at my autologger this morning and noticed the signal while I was away. I'm adding this as a new log.
    Parma, OH
    1
    I was running an OTA scan at work when I caught the 3 OPB channels. This was around noon that day. as quick as the signal was there it was gone, or they switched from ATSC 1.0 to 3.0 (unless 3.0 is downward compatible with current receivers).
    2,355
    Quote Originally Posted by Michael P View Post
    It's not — not even the same modulation scheme, which is a very good thing as OFDM allows for SFNs, better mobile reception and less interference.
