Results 1 to 3 of 3
Thread: High pitched whining with ADS InstantFM RDX-155 at stronger signal strengths
    Feb 2017
    1
    Default High pitched whining with ADS InstantFM RDX-155 at stronger signal strengths
    I have an ADS InstantFM USB tuner hooked up to a Raspberry PI. When I connect an external roof-mounted antennae, I'm getting ~90% signal strength (according to v4l2-ctl run from Linux). Unfortunately I also hear a high-pitched "whine" evident when every there are voices (no whine if there is silence). If I remove the antennae, signal strength drops to ~8%, and although there is more static, the whine is gone. I've tried a shielded USB cable with Ferrites but it hasn't helped. It seems to only happen when the signal is stronger. I also don't hear any whine with the antennae included with the tuner (~40% signal strength). Anyone have any ideas? Thanks!
    1,181
    Just a thought but could there be something in your neighborhood causing it. With the roof mounted antenna, the source could be some distance away. I haven't used mine in a long time but I don't remember any whine and my antenna was an APS-13.
    Feb 2006
    291
    If you have a "portable" fm radio, you might try extending the antenna, and walking around the house, to try and pinpoint the source of interference !
    Gary H.
