Results 1 to 10 of 17
Thread: Uh-Oh
    1,760
    Default Uh-Oh
    Here's what happens...
    ... When 80 to 100+ mph wind meets 7 ft parabolic.
    That's a 2 in diameter steel mast the antenna is mounted on.
    I think the top of the tower may also be bent a little.
    Ugh.
    Aug 2016
    Toledo
    17
    Oh no... That is terrible news, and enough to make a man shed a tear.
    I hope you quickly resolve the problem, and are back DXing.
    Chad
    639
    2" diameter pipe?? Do you know if it was galvanized? I think I use 1-5/8" diameter galvanized fence post, but then again, I'm not flying a parabolic like that.
    Aug 2007
    Franklin, TN
    193
    Thant stinks, Ed. Hope you didn't have any other damage - it was quite a line of rough storms!
    Tommy
    15 mi. N of Boston MA
    250
    Ooooh...that's awful. So sorry for you.
    2010 Honda Fit stock radio.
    Grundig G8 ultralight .
    1,760
    If I can get it all to turn, I may spin it 180 degrees and wait for the next storm to bend it back. :-)
    Andrew... Having thought about it a little more, I believe the galvanized, water pipe, mast is actually 1.875" OD with a wall thickness of .125". Whatever it is, it's not enough.
    Ham Radio operators generally agree... "If the weather doesn't, occasionally, destroy your antenna system, it isn't big enough." :-)
    I have some repair work to do on the property... No major damage but it'll be a while before I get around to fixing TV antennas.
    639
    Hey Ed, I do structural engineering for a living. So I know a bit about this kind of stuff. I'm not sure exactly what the wind load would be for a parabolic dish with mesh on it. Maybe you can find that information in an old document from the manufacturer of these antennas. That would be helpful to know. I wouldn't be surprised if there was as much as 15 to 20 psf of wind load on that surface. If that's the case, then you could be seeing 500 to 800 lbs. of lateral wind load!! And the higher up the pole that dish is, the more bending moment is created. I wouldn't feel comfortable with a pole any less than a 1/4" thick (if you can find that), and you would still want a little more than 2" diameter (if it would fit in your rotor).
    1,760
    The antenna system has gone 7 years and 8 months since it's last major overhaul (2009 ice storm). It survived 458 thunderstorm days (I keep track) and everything else Kentucky could throw at it, without any damage. The March 1st storm was one for the record books.
    (Who had 7 yrs, 8 mo in the - "How long will it last, this time?" - betting pool?)
    Andrew...The next mast might be a pipe, within a pipe, (within a pipe?)... You get the idea.
    1,760
    Just hooked up the antennas to see if they'd still work...
    ... I was afraid this might happen.
    2,290
    What exactly am I looking at?
