Results 1 to 4 of 4
Thread: La Mejor or La Raza 1460?
    May 2009
    Blaine, MN
    396
    Default La Mejor or La Raza 1460?
    I swear I hear "La Mejor" before the music starts which would be Buford, GA, but I also hear something right after the music stops. He says at least three words and then what I hear as La Mejor. What do you guys hear. The attached clip contains the original and then a equalizer filter I found in Cool Edit that kind of cuts out the clutter.
    Time: 10:20 pm-ish CDT - Sony XDRF1HD. Twin Coil Ferrite favoring E/W direction but I'm getting southerly stuff just fine.
    Attached Files Attached Files
    Justin W. - Blaine, Minnesota (EN35)
    Most used radios in order: Sony XDR-F1HD, Subaru Impreza Factory radio with RDS (not stock antenna though), Grundig G8, or Grundig S350.
    DTV dx: Insignia Tuner that everyone else has.
    DTV dx2: Vizio 24" DTV built in 2011 (hooked to Insignia).
    DTV dx3: Emerson 40" DTV built in August of 2015.
    FM Antenna: 4 Element Beam similar to the FM-6 just missing two elements.
    TV Antenna: RCA Suburban VHF-HI/UHF on the same mast as the FM antenna.
    Apr 2010
    St. Catharines, ON
    518
    "La Raza...Simplemente la mejor". Not 100 % on the "La Raza" part, however. Likely WKAM in Goshen, IN.
    Jon
    May 2009
    Blaine, MN
    396
    Thanks Jon. I was thinking Indiana was more likely! I'm not 100% sure on the la raza part either but I believe that's what he says first.
    532
    That station dominates 1460 here in Monroe County MI in the last hour of day before sunset.
    To see their coverage curve, one would not expect that.
    I almost wonder if they're "running a linear" as people called it during the CB boom.
    Comparing Sporadic-E skip to skip on the AM and shortwave bands is like comparing apples and oranges.
    Comparing tropo to skip is like comparing apples and bacon cheeseburgers.
