Page 6 of 7 FirstFirst ... 4567 LastLast
Results 51 to 60 of 67
Thread: Automated DTV scanning and logging web page
  1. #51
    Jul 2005
    Pleasant View, TN EM66
    4,363
    That's a good point: antenna motion is a real killer for 8VSB reception.
    My experience is the DJI drones are pretty stable but if the antenna is wire hanging below the drone the antenna itself may not be stable.
    Doug Smith W9WI
    http://www.w9wi.com
  2. #52
    Nov 2010
    Lebanon, IN
    101
    A very good point, Doug. I need to monitor signal quality while flying so I can see what is going on. DTV and UHF are unstable when the antenna is in motion.
    Mike Glass N9BNN
    Lebanon, IN
    EM69
  3. #53
    Feb 2016
    Easton, Pennsylvania
    69
    I doubt if your high efficiency motors are causing interference.
    If anything, there is poor isolation between the Pi-3 and the HDHR.
    Put an aluminum plate between the two units. Then shield wrap them with heavy duty aluminum foil.
    Make sure the aluminum foil of both devices are electrically connected to a negative ground trace
    of one of the USB ports.
    Yes, your drone has to be in hover mode for the HDHR to lock to the UHF signal. If the drone is moving
    3 mph it will not lock-on.
    Two questions:
    1. What is the uplink command frequency to the drone?
    2. What is the downlink video frequency from the drone?
  4. #54
    Jul 2005
    4,363
    I'd be wary of wrapping a HDHR in foil. They run rather warm with the vents exposed & I'm pretty sure it wouldn't survive long-term with them blocked. Whether you could fly it for just a few minutes without overheating I don't know.
    They sell heat sinks for some models of Pi so I'm not entirely sure that would survive a wrapping either.
    If you can still get metal window screen that might be a reasonable alternative.
    Doug Smith W9WI
    http://www.w9wi.com
  5. #55
    Nov 2010
    Lebanon, IN
    101
    The uplink is 2400 MHz, the drone did not come with a camera. I purchased it strictly for DTV DX purposes.
    Mike Glass N9BNN
    Lebanon, IN
    EM69
  6. #56
    Jul 2005
    Springfield, Missouri
    941
    I hope your DTV dxing drone experiment works. Would be awesome to report some long haul tropo dx directly over your qth that your terrestrial equipment wasn't reporting.
    Jim Thomas
    Springfield, MO
    Making FM Dxing more fun than a barrel of monkeys!
  7. #57
    Aug 2014
    Janesville WI
    361
    I've had that idea in the back of my head for a while. I thought either have a 300ohm dipole and have a bulk amount of coax or the more likely option is to do thishttps://youtu.be/tq4c86uGMmg skip to 2:25 to see the set up. But I'd try to use it on FM and record the 2mhz bandwidth.
    Janesville,WI - Sony XDR-S10HDiP & Kaito KA1103 & Insignia ND-HD01A portable 😜📻🔎📶
    FM Log - https://docs.google.com/spreadsheets...it?usp=sharing
    FM Log Map - https://www.easymapmaker.com/map/84a...2f2e84bcf806f0
  8. #58
    Nov 2010
    Lebanon, IN
    101
    My antenna on my drone is a 300 ohm dipole for UHF with a preamp that has a built in balun. It worked ok but I do better with my big dish at 30 ft than the dipole at 400 ft. It may be that DTV is hard to decode on a moving antenna.
    Mike Glass N9BNN
    Lebanon, IN
    EM69
  9. #59
    Apr 2015
    Champaign, IL
    12
    I am looking to buy an HDHR device and noticed the RabbitEars site said to stay away from HDHR4 model due to "some issues with how it reports signal levels on channels without stations actively being received". Does anyone know if a newer firmware has fixed this issue? What models are you all using for automated logging? I'm wanting to combine the tuner with a Raspberry Pi 3. Thanks for your help!
    Stan - K9SWX
    Champaign, IL
    https://www.k9swx.com
  10. #60
    Jul 2005
    941
    Stan, refer to this post for the models of HDHR most suited for automated DTV dxing....
    http://forums.wtfda.org/showthread.p...8785#post38785
    Jim Thomas
    Springfield, MO
There are currently 1 users browsing this thread. (0 members and 1 guests)
Tags for this Thread
