Page 58 of 58 FirstFirst ... 848565758
Results 571 to 579 of 579
Thread: MW DX from Enid OK by Glenn Hauser
  1. #571
    Jul 2011
    613
    Mostly Mexican MWDX to Enid OK, April 7-14, 2017
    These logs are excerpts from my daily all-band reports, mainly SWBC, also VHF/UHF, sometimes utility, ham, which may be found in several archives without much delay, such as
    http://www.hard-core-dx.com/index.php?topic=Hauser
    And compiled weekly along with extensive news from many other individuals and publications in DX LISTENING DIGEST:
    http://www.worldofradio.com/dxldmid.html
    All my MW DX reports starting August 2011 are archived in this forum with open access:
    http://forums.wtfda.org/showthread.p...-Hauser/page57
    [over 207,000 views! as of April 14, 2017]
    All times and dates strictly UT. Rx: mostly DX-398 with internal antenna only or PL-880; NRD-545 with ALA-330S inside E-W or inside randomwire N-S; Nissan stock caradio as specified; ICR-75 E-W longwire
    ** MEXICO. 650, April 14 at 1157, good signal from XETNT, Los Mochis, Sinaloa, which really gets out on skywave. Much better now than any other XE in the 500s, 600s or 700s, altho 730 XEHB Chihuahua is weakly audible too. XETNT with music, 1159 full ID for XHTNT 106.5 and XETNT 650, both Radio 65. 6 am timecheck, announces newscast, but not yet, back to songs. Today`s Enid sunrise: 1159 UT on way to earliest of the year in about two months, 1113 UT (Glenn Hauser, OK, DX LISTENING DIGEST)
  2. #572
    Jul 2011
    613
    Domestic MWDX to Enid OK, April 7-14, 2017
    All times and dates strictly UT [4 hours ahead of `ELT` during EDT; when changing times one must also change the dates for events in the 00-04 UT period to the previous date by ELT].
    Rx: mostly DX-398 with internal antenna only or PL-880; NRD-545 with ALA-330S inside E-W or inside randomwire N-S; Nissan stock caradio as specified; IC-R75 with E-W longwire
    These logs are excerpts from my daily all-band reports, mainly SWBC, also VHF/UHF, sometimes, utility, ham, which may be found in several archives without much delay, such as
    These logs are in four sections, Canada [if any], Oklahoma [if any], rest of USA [if any], unidentified [if any], separated by ======= Within each, they are in frequency order
    ** OKLAHOMA. 930, Friday April 14 at 1228 UT, WKY with no morning DJ show which was still shown on their website April 1, but repeated IDs as ``930 AM WKY Deportes`` The call letters always pronounced in English. String of national and local ads & PSAs, including one in English for an OKC Low-Testosterone business --- sports fans have got to keep it up! 1232 UT plugs WKY carrying Texas Rangers SBGs. 1233 UT rejoins network ESPN Deportes.
    The website still uses the old name,
    http://www.laindomable.com/
    but has wiped musical show info, except for this presumably now outdated about the DJ known as The Roadrunner, (tho check to be sure whether he`s not on M-F at 21-01 UT). I am preserving here for posterity [sic without fixing up accents, horrendous comma splices]:
    http://www.laindomable.com/shows/jos...-correcaminos/
    ``20160421_JoseJaimeLeo-27 [portrait]
    http://www.laindomable.com/wp-conten...71-300x200.jpg
    Mi nombre es Jose Rivera, me apodan El Correcaminos, naci en Nuevo Laredo, amps. Mexico en un 22 de Mayo de 1900 y algo, desde niño me gusto’ la locucion, no fue’ hasta finales de los 90’s que se me dio’ la oportunidad de estar en una radio al aire, en el 1340 AM, la caliente, con Chuy Vega, estaba en aquel entonces en ventas y chuy me daba la oportunidad de entrar al aire en su show, trabaje’ un tiempo , deje la radio, en Agosto del 2001, un amigo de nombre Mathew Mollman, me dio’ la oporunidad de ayudar en su estacion por 2 semanas, y entre’ a trabajar en la 106.7 para un total de 3 años y medio. La Indomable me contrato’ un 14 de febrero del 2005, y aqui estamos, gracias al publico, ahora de 4-8 PM. Me encanta la musica, especialmente el rock en español, amo la cumbia, la clasica, la norteña, la banda, la punta, la rumba, el danzon, la characa, el merengue y la salsa, me gusta toda la comida en moderacion, Tacos de Carne Asada, Abichuelas con Arroz, un buen Caldo 7 mares y un buen Sirloin con Camarones. Me gusta ayudar a mi gente, complacer a mis radioescuchas y siempre estar al tanto de lo que pasa en Okc, La Union Americana y el mundo entero. Si le gustaria conocerme mas a fondo, lo espero de 4-8 de Lunes a Viernes, Aqui, en La Indomable 930AM`` (Glenn Hauser, Enid, DX LISTENING DIGEST)
    ** U S A. 1480, April 7 at 0122 UT, South Asian song is somewhat atop the QRM, so apparently KBXD Dallas is still on with R. Namaste. I was wondering, since haven`t heard it in some time. Best to check around sunrise (Glenn Hauser, OK, DX LISTENING DIGEST)
    ** U S A. 1480, April 9 at 0650 UT past 0703 UT, South Asian songs are dominating, presumed KBXD Dallas with Radio Namaste, and suspected on 50 kW day power/pattern. No announcements heard unless while I dozed off (Glenn Hauser, OK, DX LISTENING DIGEST)
    ** U S A. 1480, April 14 circa 1200-1230 UT, no R. Namaste from KBXD Dallas unless it`s the SAH vs dominant KQAM Wichita. Should be in on SRS with 50 kW day power; meanwhile KTNO Spanish religion also from The Metroplex is good and dominant on 1440; so is KBXD off again? Recently was hearing it dominant at night (Glenn Hauser, OK, DX LISTENING DIGEST)
  3. #573
    May 2008
    Thunderstorm, KY
    1,666
    "... including one in English for an OKC Low-Testosterone business --- sports fans have got to keep it up!"
    Reminds me of XERA (eventually, XERF) and the, "goat gland" cure.
    73, Ed NN2E
    Owner / Operator - Murphy's Law Test Site & Thunderstorm Proving Grounds
    "You Might Be a Redneck If...
    Your TV is on 24/7.
    Your TV has been permanently on for over a decade.
    The only time your TV is off is during a power outage.
    Your TV gets 512 channels, but you go outside to use the bathroom.
    Your new TV is sitting on top of your old TV.
    Your TV costs more than all of your other furniture.
    Your deer-stand has a TV antenna on it.
    Your cable provider has no idea that you exist."
    Jeff Foxworthy
  4. #574
    Jul 2011
    613
    Domestic MWDX to Enid OK, April 15-21, 2017
    http://forums.wtfda.org/showthread.p...-Hauser/page58
    [over 209,000 views! as of April 21, 2017]
    ** OKLAHOMA. 930, Sunday April 16 at 1228 UT, tune-in just in time to hear closing of weekly 7 am CT pubaffs show in English, `Sunday Morning Magazine` which WKY is still carrying post-flip to SS ESPN Deportes elsewhen, inviting potential guests to contact them; immediately back to Spanish ID. Previously also heard but not synchro on sibling KWPN 640, both licensed to RADIO LICENSE HOLDING CBC, LLC along with some FM stations (Glenn Hauser, OK, DX LISTENING DIGEST)
    ** OKLAHOMA. 1390, April 20 at 0609 UT, local KCRC is open carrier/dead air. STILL so at next check 1211 UT --- I bet it was thus all night, no one caring or noticing at station which lost plugin from a sports network. Sibling 107.1 KNID is still alive at 1221 UT check, you bet! That`s what matters. By next check 1345 UT, KCRC has resumed stupid sportstalk.
    Lack of splatter made DXing 1380 and 1400 easier, but nothing definite; two SS on 1380, probably Houston and Tulsa (Glenn Hauser, Enid, DX LISTENING DIGEST)
    ** U S A. IBOC checkup on major CBS AM stations, April 19 at 0148-0150 UT: NOT heard around 1160 KSL, 1120 KMOX, 830 WCCO, 780 WBBM; maybe still on 670 WSCR; noise definitely still infesting 1080 KRLD. Altho updated 21 March 2017, I think quite a few more here are now ex-IBOC:
    http://topazdesigns.com/iboc/station-list.html
    ** U S A. 1380, April 15 at 0446 UT, Spanish religion about ``el caudillo de Israel``, i.e. KRCM Shenandoah TX, probably on 22 kW day power (Glenn Hauser, OK, DX LISTENING DIGEST)
    ** U S A. 1480, April 15 at 0445 UT, South Asian songs dominating again this time of night, no doubt KBXD Dallas (Glenn Hauser, OK, DX LISTENING DIGEST)
    ** U S A. 1640, April 15 at 0437 UT, local KZLS (Alex Jones accusing salon.com of lying about him; he makes me want to puke), with an understation, traces of Spanish. Rather than Argentina or Perú, I`m confident it is KBJA Sandy UT, the only SS known in North America on 1640. No sign of WTNI Biloxi MS with silly sportstalk in English, which is the usual understation, and often QRMing KZLS as if on daypower (Glenn Hauser, OK, DX LISTENING DIGEST)
  5. #575
    Jul 2011
    613
    Mostly Mexican MWDX to Enid OK, April 15-21, 2017
    [over 209,000 views! as of April 14, 2017]
    ** MEXICO. 800, April 20 at 1303 UT, after Mex NA, sign-on by a station with address in Ciudad Juárez, seems to mention FM 102.7. As usual, a struggle to copy weak signal, no borderblaster, with near-local KQCV OKC nulled as much as possible.
    XEROK, Radio Cañón is not known to have an FM, but adding that is certainly the trend on both sides of la frontera. Wikipedia gives website as http://calibre800.com/ but that`s the newscast it carries, not the station per se, and no sign of an FM mentioned there. 102.7 may be wrong, as there is a K-love translator on that in nearby Anthony TX, altho as such would be subject to bumping by a US non-translator, and presumably Mexican (Glenn Hauser, OK, DX LISTENING DIGEST)
  6. #576
    May 2014
    Arizona
    1,994
    XEROK couldn't migrate if it wanted to — no migration frequencies were made available for Juárez.
    The only 102.7 allotments the FCC has in Chihuahua are in Ciudad Guerrero, which is west of Cuauhtémoc, and a "locality" (seemingly a few houses) called Cajoncitos, which is in the middle of nowhere on the international border.
    I'm trying to figure out where in the world this came from and nothing is making sense.
    Este programa es público, ajeno a cualquier partido político. Queda prohibido el uso para fines distintos a los establecidos en el programa.
    Read the Mexico Beat | Download Mexican FM Station Coordinates v2 | View my HD Radio in Mexico map
  7. #577
    Jul 2011
    613
    Mostly Mexican MWDX to Enid OK, April 22-28, 2017
    [over 211,000 views! as of April 28, 2017]
    ** MEXICO. 570, April 28 at 0455, dominant signal here with choral NA early, stops at 0456 but no ID, so sign-off? Nothing further heard. Loops south, so I would expect XEBJB Monterrey NL. IRCA Mexican Log as of 2015 showed XEBJB as 24 hours, but some others going off at 0500 or 0600 (Glenn Hauser, OK, DX LISTENING DIGEST)
    ** MEXICO. 800, April 27 at 1200 UT, XEROK with choral NA, near-local KQCV OKC nulled as much as possible. This time I can copy enough of the full ID which follows at 1202 to tell that Radio Cañón with street address is *not* mentioning an FM frequency with a seven in it, but instead after 800, they say ``Grupo 7`` (Glenn Hauser, OK, DX LISTENING DIGEST)
  8. #578
    Jul 2011
    613
    Domestic MWDX to Enid OK, April 22-28, 2017
    ** OKLAHOMA. 596 kHz, April 22 at 1838 UT check, high noon, still JBA carrier which I traced months ago to a spur out of 1640 KZLS, east of Hennessey (Glenn Hauser, Enid, DX LISTENING DIGESET)
    ** U S A. IBOC noise check around 0456 UT April 28: 670 WSCR, 780 WBBM, 830 WCCO, 1080 KRLD (Glenn Hauser, OK, DX LISTENING DIGEST)
    ** U S A. 690, April 28 at 0454 UT, outro from a network (?) called Radio One, then local weather from KGGF Coffeyville KS, axually from a YL weatherperson at NewsOnSix = KOTV-45 (for a while longer), Tulsa. I continue to lament that KGGF no longer carries Jim Bohannon at 02-05 UT, which used to be our best source, so at 0457 UT I check whether he`s still on: KWTO 560 Springfield MO, KFEQ 680 St Joseph MO --- yes, he is. KWTO is where he worked early in his career. I don`t find a network named Radio One in the list on page 271 of the NRC AM Log, nor as a station group on page 276, nor as a show on page 272.
    `When Radio Was` is on the schedule at 11 pm-midnight CT M-F
    http://kggfradio.com/kggf-am/kggf-am-line-up
    ** U S A. 770, April 23 at 1214 UT, steady signal mentions crawfordbroadcasting.com and loops N/S. Surely it`s my nearest at that angle after sunrise here, KAAM Garland (Metroplex) TX. But that station is not licensed to Crawford, and the website shows their only 770 is KCBC San Francisco (Manteca) CA, certainly not what I am hearing with its lobes into the Pacific, even if on 50 kW cardioid day pattern. KAAM program schedule
    http://www.kaamradio.com/schedule/
    states merely `public affairs`` for 7-7:30 am Sundays. Apparently they carry some Crawford program (Glenn Hauser, OK, DX LISTENING DIGEST)
    ** U S A. 1020, April 28 at 0500 UT, singing ID for Radiovisión Cristiana (1330 NYC), so KCKN Roswell NM is currently active, and plenty to QRM KOKP Perry OK with a heavy SAH, let alone KDKA Pittsburgh PA which it is supposed to protect (Glenn Hauser, OK, DX LISTENING DIGEST)
    ** U S A. 1030, April 23 at 1221 UT, IDs as ``Real Country 1030 AM, KCWJ`, i.e. Blue Springs (Independence) MO (Glenn Hauser, OK, DX LISTENING DIGEST)
    ** U S A. 1140, April 23 at 1223 UT, jazz show with classic performances from 1948, 1949; 1241 UT Miles and the Nonet. Tight DF for NE/SW, atop some SS QRM from AR or NL, 1258 UT finally YL talkover mentions Kansas City, so KCXL Liberty MO, now on 4 kW non-direxional day power. Name of show in passing sounded like ``Neon Jazz``, but program schedule http://www.kcxl.com/shows.html lists `Neon Beat` at 6-8 am CT and all afternoons Saturdays & Sundays, otherwise far-right extremist talk shows (Glenn Hauser, OK, WORLD OF RADIO 1875, DX LISTENING DIGEST)
    Re: ** U S A. 1640, April 15 at 0437 UT, local KZLS (Alex Jones accusing
    Glenn - re 1640 don't forget Juventus don Bosco from Dominican
    Republic. I have pointed out to the editors that the current edition
    of WRTH omits all Dominican Republic stations from their Central
    American listings. 73 (/Andrew Brade, England, DX LISTENING DIGESET)
    O yes, I had a gnawing feeling something was missing. But still KBJA
    would be far more likely here. DR is of course not in Central America,
    but grouped with Caribbean, Bermuda & Mexico for the by-frequency
    pages in the back, no DR at the end of the list on page 551. The
    National Radio page for DR, 186, does include that 1640 station, plus
    others on 1620, 1670 and 1680. They were all in the 2016 edition page
    551; strange (Glenn Hauser, DX LISTENING DIGEST)
  9. #579
    May 2014
    Arizona
    1,994
    Quote Originally Posted by Glen Hauser View Post
    That makes a lot more sense. Grupo Siete Comunicación is the full name of the company.
    (Speaking of which, their own site doesn't list XHEOB-FM, a common head-scratcher...)
There are currently 3 users browsing this thread. (1 members and 2 guests)
  1. NN2E
