Page 2 of 7 FirstFirst 1234 ... LastLast
Results 11 to 20 of 69
Thread: Houston, we have a problem.
    Ed, that sounds like a good start.
    My experience with Microwave Filter Company products has been positive.
    Too bad these cell companies don't feel obligated to supply cut-off/band pass filters for those OTA viewers that have preamps which now suck in what used to be broadcast TV frequencies. When KBEJ-2 tested their 100-kw in Apr 2000 they immediately creamed many nearby CATV headends (and probably no small number of OTA folk with preamps for WOAI-4/KENS-5). They likely spent the time until full-programming (Aug) distributing Ch 2 traps !
    As far as the FCC goes... I'll save them as a last resort. I've been dealing with them for 40+ years and would rather not get them involved unless absolutely necessary. I'm collecting plenty of documentation / pictures (they just love documentation) in case I have to go that route.
    One thing to keep in mind with interference cases... You really need to be sure everything involving your equipment is in order before pointing a finger (which finger you choose is up to you) :-) at the source of the problem. Bugging the FCC about a problem that might actually be yours is not gonna be productive.
    I'm a little leery of the Rad-Shack filter. The specs look OK but Rad-Shack has had issues with some of their TV stuff in the past. Anyone remember the Rad-Shack TV pre-amps of about 30 years ago? They turned out to be better oscillators / transmitters than pre-amps.
    I don't think the FCC can do anything here since they are broadcasting on their licensed frequencies.
    The Radio Shack filter is cheap so I imagine its not the best filter out there. It likely has a large transition band that ends up attenuating the upper TV channels slightly. A more expensive filter will probably do a better job.
    Ed knows this, but for anyone who doesn't, MFC is professional grade equipment. It is used by cable systems and other commercial users.
    In the past, I used their bullet traps for local analog channels 3, 6, and 12. I also use a MFC trap for the spectrum between channels 4 and 5. My TV log would be considerably smaller without MFC's help.
    Ed, as I haven't seen any posts from you in a few days, I hope you are well and making progress on the interference problem.
    I'm OK, Danny.... I've been blocked from the TV/FM SkipLog, for about 5 days, so that's why no posting, there. Not much to report, anyway, as we're stuck in the no tropo / rain / thunderstorm / antennas disconnected mode, here.
    Even with all of today's instant communication (cell phones, E-mail, etc) I've yet to get any relevant information out of the local cell site manager.
    So... I've gone ahead and ordered both, the Rad-Shack, part #15-396, low-pass filter, for $9.99 + shipping and the MFC, part #3322-698/732, low-pass filter, for $195 (ouch) + shipping. I'll test them, whenever they get here, and post the results in this thread.
    I'm glad you are OK and the filters have been ordered.
    Well, I've gotten a bit of info on the cell site... The current QRM is thanks to Verizon. AT&T also has plans to operate from this site in the future. Oh, goody. I've looked at the band plan for this 700 MC stuff but it's a bit vague on exactly what frequencies will be used to transmit from the site. I pray they don't use the low end of 700 MC (right above ch 51) for transmit. The filtering to remove QRM, that close to the TV band, is gonna be VERY expensive, perhaps, into the thousands of dollars. I hope the filters I've ordered will do the trick. I've spent waaay too much on this problem, already. I'm not happy.
    In the interest of further knowledge, I thought I'd take a look at what the cell site QRM does to an analog signal. I've used local WQTV-LP 24 Murray, KY. (abt 20 mi from here... I can't hide from it) as a signal source...
    Here's what WQTV-LP normally looks like.
    And here's what the cell site QRM does to it.
