Hey guys...
Just wanted to post up about the STELLAR LABS 30-2460 FM YAGI Antenna...
Maybe you all already know about this but wanted to pass along the info just in case some did not...
With the demise of the Winegard FM-6 FM Yagi (And all the other bigger FM Yagis) I was pondering on
the future of distant FM broadcast reception (I had used a FM-6 for FM reception here in Nevada where all the stations are
located 60 miles away with mountains in between)...
Then about a week ago I got an ad for some antennas and there was an FM YAGI antenna!!!...
I decided to give it a try ordering it through Amazon for $30 DELIVERED...
Well the box this antenna comes in is paper thin and the first one I received was bent and the beam had a crack
so I told MCM Electronics and they sent another out immediately. I got the second one and it had only a few elements
bent that I could easily straighten...(The box really needs to be improved)...
Anyway I did some checks on signal strength checks on the roof with the FM-6 connected to a wideband handheld scanner.
Then I took down the FM-6 and put up the new Stellar Labs 30-2460 FM Yagi (This antenna is much lighter than the FM-6
and construction is not as high quality as the FM-6 but because of it's light weight I'm hoping that helps...We shall find out
as I live in a wind prone valley where 30 to 40 mile hour gusts are common and go much higher in the winter)...
Well...I was pleasantly surprised with the performance of the new antenna vs. the FM-6...The Stellar Labs antenna
actually had a "little" more gain than the FM-6 for the stations I checked.
So it seems there is an inexpensive option available on the market to replace the FM-6...
For those of you who have not invested in an INNOVANTENNA spending the big bucks and who may in the future
need to replace the FM-6 this antenna is a decent option...
Here's the URL...
http://www.mcmelectronics.com/produc...tenna%26rk%3D4
Like I said I ordered it from them through Amazon for $30 delivered. They're showing $19.99 for their price so you'll have to check shipping to see which is cheaper...
CHEERS!!!
OH...I see that K6STI has already done antenna modeling on this antenna...
http://ham-radio.com/k6sti/stellar.htm
Here's the URL...
CHEERS!!!
