If this is your first visit, be sure to
check out the FAQ by clicking the
link above. You will have to sign up
before you can post: click the sign-up link at the top right corner of the page to proceed. To start viewing messages,
select the forum that you want to visit from the selection below. Please login at least once every 90 days to keep from being deleted as an inactive user. New users may be moderated until their first post. We reserve the right to put users on moderation or to remove users from the Forums without notice if necessary.
The VUD Forum is back. It's located in the WTFDA Members Area. You need to be registered and a WTFDA member to access this forum.
***The MAY 2022 VUD is now available.***
Well, I have one of the so-called legend parabolic antennas, and wanted to inquire to the team if this would be worthwhile to install over my existing stack of 91XG's.
Here is a quick link to a simple video I made to share.
i had one back in the 70s, and it was awesome. As Gary said - IF you can keep it in the air, because unfortunately mine was a victim of wind twice, in spite of using plumbing pipe as a mast the second time. But it's definitely a super performing antenna.
I would say go for it and install your CM 4251. Mike G. and I replaced a horizontal stack of 91XGs with a Finco P-7 (a 7 ft. parabolic that rivals the 4251) at our remote controlled DTV DX site near Milford, IL, 85 miles south of Chicago in May. At this rural site both antenna setups work very well but I do believe some of the new DTV logs since the P-7 was installed are partially due to it having a little better directivity. About two-thirds of the P-7 is lined with chicken wire to help improve its F/B ratio.
DTV DXer Ed in KY also uses the P-7. There are several DTV DXers using the 4251. Please keep us posted on your decision.
This little project of mine, has turned into an "addictive" hobby. In fact, I have really enjoyed refurbishing this antenna. I replaced the metal rivets which attach the bow ties to the feed as they were not allowing perfect contact for full signal transfer (corroded). I drilled out all the rivets and wanted to replace with aluminum hardware, which I was unable to find. So, I went with stainless steel. Also, replaced the hardware where you connect the 300 ohm to balun.
My existing system has a stack of 91XG's and a Funke 1922 from Greg B.
Any feedback would be great, as I am uncertain if the parabolic will outperform my existing system. (Then, I have the added wind load of the parabolic at 50')
In your picture, how high are the 91XG's ? If you install, the 4251, I would suggest, that you use 1" I.D. Black pipe. Might have to use bigger U-bolts and it is heavy, but, much less likely, to bend !
After seeing the great condition of this completely reworked Channel Master 4251 by Chad, I contacted him. I used to DX with the 6 ft. version, the 4250, back in the 1970s while I was in college, and I really wanted to get this unit. Chad and I came to an agreement and when we met at KAS Satellite and Antenna, Inc., Angola, IN for an antenna shoot out https://www.facebook.com/chad.bryan.90 a week ago Saturday, Chad brought the antenna with him. I installed it on the tower at my house in Indy Friday afternoon. It was almost as good as a new one I helped a friend install in July 1975. A few pictures installing the 4251 are attached. My house is not in the most favorable location for DTV DX, but the 4251 was receiving Detroit DTV at around 230 miles this morning. Thanks to Chad for this great antenna and all the time and effort he put in making it look and work so great again. Some special TLC.
I just completed the refurbishment of another Parabolic, and listed it in the Buy/Sell section. In fact, I placed some of my other (new) antennas in there as well. I just have too much, and decided to see if any of the members had an interest.
I really enjoy working on these vintage antennas, as it is a wonderful hobby to see a beautiful antenna at the end of the process.
I know of two 4251's, here in the county, that I suspect are no longer in use. (Little satellite dishes in the yard) If I were 30 years younger I'd see about obtaining them. (I'm gettin' old and tired of climbing towers)
A 7 ft parabolic is not easy to keep in the air...
... so, the installation needs to be as 'bomb-proof' as possible.
What I really need is a new Channel Master 3617B VHF to replace my broken Antennacraft CS-1100.
