Hello all, I just moved into a subdivision that (Thank GOD) doesn't have the devils children a/k/a HOA with the new secret CDD fees but the county has code enforcement officers, the rule book is rather ambiguous about anything non satellite & nothing is even mentioned about Congress mandated availability of OTA analog TV system antennas if one elects not to go Cable or Satellite. I already have cable but this is for the hobby. I have my eye on the Comet CD-95Y FM Yagi which has a fairly small footprint of 45" in length but the width of the longest element is a whopping 71" & that's noticeable, even if I mount it right on the roof peak vent plate with a rotor you cant miss that so now I'm eying the Terk FM50 which is 57" wide which I believe I could pull off, only problem is it's bidirectional which would render it useless for DX but what if I attached a metal plate on one side wouldn't that give it directional characteristics like the Navy carrier radars that have the transmitting elements attached to big metal plates? I know, try it & see, I just threw this out there in case anybody is familiar with these two antennas or have had HOA issues & how have they been circumvented, thanks in advance. Everybody please have a safe & pleasant weekend.
BTW: The attic is out because the roof insulation is aluminized & I added custom aluminum laminated flooring to the attic because all my SDR's will be run via USB cable from the PC's to the attic to eliminate the AC hash from the house.
