Today I received the FM-6, after 6 days in transit (the world not on time Fedex).
Installation was pretty smooth, although its a bigger antenna than I thought. This is good though, right? Currently it is sitting on its own mast, and I can rotate everything by hand. That would require going up on the roof every time I need to change the direction though.
I am thinking about hijacking my TV antenna's rotor, and putting the FM6 on top of it. The antenna will sit directly on top of the plastic section of the UHF half of the antenna. I am going to remove the worthless VHF section, since it isn't hooked up anyway, and I get better picture without it.
As I said, it will sit on the TV antenna, pointing the same direction. I plan on keeping it strapped down with some cable ties. There is sufficient room for the FM6. I still want to be able to use the TV antenna, if the MUF would ever get high enough here during skips. Should I leave some space between the antennas so they don't interfere with each other?
I will post some pictures of the whole debacle soon. Heading to NYC in two days though. Watch, while I'm gone, the biggest opening in history will happen. Law of life, that is.
