If this is your first visit, be sure to
check out the FAQ by clicking the
link above. You will have to sign up
before you can post: click the sign-up link at the top right corner of the page to proceed. To start viewing messages,
select the forum that you want to visit from the selection below. Please login at least once every 90 days to keep from being deleted as an inactive user. New users may be moderated until their first post. We reserve the right to put users on moderation or to remove users from the Forums without notice if necessary.
The VUD Forum is back. It's located in the WTFDA Members Area. You need to be registered and a WTFDA member to access this forum.
***The MAY 2022 VUD is now available.***
Did you notice, at the bottom of the Summitsource ad, that the HD-6065 ant. has been replaced, by the HD-6055 ant. The boom lenght is 82" !
Is this 12'x12 'room upstairs or ground level? If you can't mount it outside, then the attic, would be next choice. Height is Very important.
Very good choice, of antenna...
