Amps in the Attic?
  • Amps in the Attic?
    Here is what I did to get the power supplies to my antenna mounted preamps up close to the antennas. I took scrap 2x4's and a scrap pine plank and secured them between the rafters supports. A 120 VAC outlet was installed, power supplies mounted, and then splitters put in to send the signal to wall late mounted F connectors in the master bedrom and cables in the radio room.
    Plus now I don't need to drag a extension cord into the crawlspace anymore!
    Two photos-amp board and Twin Trucker cb antennas. Also you can see the extended double-zepp cut for 27mhz, feed with 450 ohm feedline.
    Guy in Lockport, NY
