5/30 Es unids
  • 5/30 Es unids
    Attached are some unids from the 5/30/20 Es event. As usual, any help will be appreciated. Hopefully something in one of these will be familiar to someone else.
    Thanks-
    The 103.5 sounds like "103.5 The Wolf" but that matches nobody. Can't pull out much else.
      The 104.1 sounds like "Froggy 104" to me. If so, that would make it WOGY, Jackson, TN. If your in PA, that would be some short Es though....
        I believe that the 104.1 is indeed WOGY. This season has been full of short skip - Columbus, OH included. Thanks-
          103.5 has to be either WIKK Newton, IL or KRFX Denver, CO, based on the fact they are playing classic rock. The dj says "...from Apollo 11 in '69, Space Oddity David Bowie. 1 0 3 5 <The no ?>" and leads into Steely Dan's "Reelin' In The Years".
            As much as I'd love for it to be Denver, there wasn't any 2x at the time and the band had gone short and into Illinois, so WIKK certainly fits. Furthermore, I was able to ID WIKK about 15 minutes later. Thanks !
