FM antenna that is available and maybe better than the Stereo Probe 9
It IS the Stereo Probe 9, just back in production and made by Sky Blue Antennas of Minnesota. I read that this is sturdier than the original SP9, which I use daily and I think mine is made well.Enfield, CT USA
See what else I have over there.
Makes you want to cry, doesn't it?Enfield, CT USA
I have been using the new SBFM-9 for about two months now. I also keep careful measurements of the noise floor level at each 10 degrees of azimuth, and the mid-day signal levels of a handful of locals and semi-locals. I can only compare the antenna to my Korner 9.2 and an Antennacraft FM6 which have previously been mounted on the same rotor at the same height.
The SBFM9 has about 3 dB more forward gain than the Korner 9.2 and about 4 dB vs. the FM6. It's F/B ratio is inferior to the Korner 9.2, but much better than the FM6. The antenna is very sturdy and well suited for long-life outdoors. Assembly is straightforward.
In one of the worst seasons that I can recall, the antenna has still managed to put new stations in the log on both tropo and meteor scatter.
I plan to remove the printed circuit board balun, and replace it with the Channel Master 3203 high-performance matching transformer instead. I expect this to provide a bit less loss and improve performance even more.
Highly recommend purchasing this if you have anything smaller than a 9 element Yagi currently.
- Likes 1
