Coastal Ducting Today
    It appears that there was some coastal ducting during this morning's crop of Required Weekly Tests (RWT). In Oak Island, NC, on 162.400 PiWxRx decoded a RWT from KIH26, some 370 miles away. KIH26 is located in Daytona Beach, FL. Reception of this Florida station would indicate that it was strong enough to overcome the semi-local station on frequency, KEC95, covering the Myrtle Beach, SC area. KEC95 is around 56 miles away. KIH26 is programmed by the Melbourne, FL Weather Forecast Office.
    The receiver is a 1960's era Motorola Motrac "M" receiver. The antenna is outside with about 3 dB of gain. Inside the shack, the antenna is split 4 ways through a CATV splitter and feeds other WX receivers. There is no preamp - everything is barefoot.
    The National Weather Service has issued a Required weekly test at
    11:09 local time on 2024/5/29 for the following area(s):
    This weather alert is in effect for the next 02:00 hours
    KEC95 can be heard on MeshPhone 910-4161
    The 075xxx codes are SAME codes for marine zones. The four codes referenced in this report correspond to:
    [ "075454" , "075454 Coastal waters from St. Augustine to Flagler Beach, FL out 20 NM" ],
    [ "075474" , "075474 Offshore waters from St. Augustine to Flagler Beach, FL from 20 to 60 NM" ],
    [ "075550" , "075550 Coastal waters from Flagler Beach FL to Volusia-Brevard County Line out 20 NM" ],
    [ "075570" , "075570 Offshore waters from Flagler Beach, FL to Volusia-Brevard County Line from 20 to 60 NM" ]
    As usual, this Alert and others can be found on my N2MH-MeshChat-WX web page on the AREDN Mesh.
    73, Mark, N2MH​
