Meteor Scatter Logs in Ohio
    In the past couple months, I've tried using the FM Stellar Labs yagi mounted in my backyard on a tripod aiming straight up at the sky, and it's yielded some good results for meteor scatter. It has helped lower my noise floor significantly despite being 1.6 miles and 2.0 miles from the nearby FM broadcast towers here in Akron. I also believe that aiming the antenna straight up has helped capture more meteor scatter bursts. With the technology now, using SDR Console and the FM autologger, it helps make meteor scatter easier than ever. I simply just park the SDR on about 10 open frequencies and hope that RDS decodes on any of them while away. Here is a list of the meteor scatter logs I've received in the past couple months of doing this (September & October)...
    95.7 KWWR Mexico, MO 570 miles
    99.9 WEZN Bridgeport, CT 438 miles
    100.3 WNSL Laurel, MS 779 miles
    101.5 WRAL Raleigh, NC 407 miles
    101.5 WSOL Yulee, FL 707 miles
    101.9 KMVX Monroe, LA 842 miles
    102.7 WJEQ Macomb, IL 474 miles
    103.5 WEZL Charleston, SC 576 miles
    106.3 WQBZ Fort Valley, GA 584 miles
    106.3 KLXH Thibodaux, LA 938 miles
    107.5 WBYN Boyertown, PA 316 miles
    Extremely interesting report.
    Those MS FM logs are very impressive.
    The straight-up antenna appears to be a good idea.
    North Louisiana
      Here are some more meteor scatter logs from November up until now (12/15/22). These are all newly logged by meteor scatter (received here in Akron, Ohio)...
      92.7 WCMI Catlettsburg, KY (186 miles) completely filling out all RDS fields
      92.7 KLOZ Eldon, MO (613 miles) "Mix" ID
      93.9 WMMA Nekoosa, WI (471 miles) w/RDS
      93.9 WMTM Moultrie, GA (689 miles) w/RDS, logged twice
      94.3 KKIN Aitkin, MN (711 miles) "That's your KKIN forecast"
      94.7 WZOR Mishicot, WI (387 miles) w/RDS, logged 3 times
      95.1 KICT Wichita, KS (876 miles) w/RDS
      95.7 KDAL Duluth, MN (655 miles) w/RDS
      102.9 WMKC Indian River, MI (351 miles) w/Big D & Bubba morning show
      103.5 WKSC Chicago, IL (317 miles) w/RDS and The Fred Morning Show
      103.5 KNEI Waukon, IA (527 miles) callsign mention
      103.9 WAWY Dundee, IL (357 miles) Air1
      105.3 WHTS Coopersville, MI (269 miles) w/RDS
      105.5 KRBI St. Peter, MN (666 miles) w/local ad for business in Mankato
      105.5 WCOO Kiawah Island, SC (578 miles) w/RDS
      105.9 KICP Patterson, IA (636 miles) classical music that coincided with 107.5 Des Moines
      106.7 WKRU Allouez, WI (398 miles) w/local ad for buisness on Mike McCarthy Way in Green Bay
      106.7 WPPN Des Plaines, IL (337 miles) Spanish w/local ad
      107.5 WDUZ Brillion, WI (396 miles) w/local ad for Joe's Service & Used Cars in De Pere
      107.5 KKDM Des Moines, IA (607 miles) w/Elvis Duran Morning Show
      107.5 WCCN Neillsville, WI (518 miles) w/RDS​
        When you say pointing the antenna straight up... What exactly do you mean?! Yagi antennas are horizontal designed... Aren't they?!
        Trying to earn something here.
          I'm literally pointing the antenna up at the sky. It doesn't seem to matter which direction it's rotated; it works any way. So all the horizontal elements are parallel to the ground.
