I have added some new TV antennas and associated equipment. All of the new antennas have been mounted but some custom antenna selection equipment needs to have its construction completed. The equipment is summarized below:
The combination of filters and selective combiners is used to prevent mixing of unwanted local signals from off-frequency antennas hurting reception of DX from the more directive antenna. The selectivity of the HD HomeRun tuner seems to be worst of the low VHF channels. The filters there help prevent overload and IMD from FM stations hurting low VHF reception. The installation to the 10A3F120 tuner has been completed. Its reception can be observed at https://rabbitears.info/tvdx/one_tun...0A3F120/tuner0
I will include some pictures of my new antennas. I have long had a 9-element custom antenna for channels 2 and 3 and a 10-element custom antenna for channel 6 and the lower FM frequencies but nothing specifically for channels 4 and 5. Using some surplus tubing that I have a 7-element antennas channel 4 and 5 was recently installed.
The top antenna is a Winegard HD7698P with the new channel 4 & 5 antenna just below that. A fixed direction Stellar 30-2440 is side mounted on the tower.
I redesigned the Televes 149783 UHF antenna. Twelve elements were added, and the length of all directors was extended.
My 10-element channel 6 antenna is on top.
I thought that I would try something different and install my first vertically polarized TV antenna. It is just a side-mounted vertical dipole tuned best for channels 2 and 3. It is spaced from the tower to produce the following pattern:
It is shown below with my 9-element channel 2 & 3 antenna just above it.
There has not been much tropo or Es opening recently (or expected in the next week) hurting evaluation of the new antennas.
